 Hobby
 Subscriber Log-in
 Get Web Access
 Magazine E-Library
 Classifieds
 Aircraft Directory
 Supplier Directory
 Reader Feedback
 SportPlanes
Links
 Back Issues
 Shopping
 Bookstore
How to Advertise
 Event Calendar
Flight Testing: Finding TAS from GPS Data
If you do the math right and use proper flying technique during test runs, you can arrive at an accurate number.
By Kevin Horton
How fast does your aircraft go? You could grab your trusty E-6B and use your airspeed indicator (ASI) reading, pressure altitude and outside air temperature (OAT) to calculate true airspeed (TAS). But if you are flying an Experimental/Amateur-Built aircraft, you may not know what the static source position error is. And your ASI probably has instrument error. What is a guy to do? The GPS is the answer. We can use the groundspeed information from the GPS to calculate TAS, as long as we are careful to use a method that is mathematically sound.
Electronic Subscribers: Click Here for the Full Story
Non-Subscribers: Click Here to Subscribe
Pay Per View ($7.50)
Headlines
KITPLANES sits down with Advanced Flight Systems' founder Rob Hickman to examine his new synthetic-vision EFIS.
JPI's Lance Turk explains the features of the new JPI EDM-740.
Ever wonder what it takes to be the largest kit manufacturer in the world? KITPLANES editor Marc Cook takes a tour of Van's Aircraft in Aurora, Oregon.
KITPLANES editor Marc Cook visits Matco Manufacturing near Salt Lake City to see how the company's brakes, wheels and master cylinders are built.
Get an inside look at how Dynon builds and tests its electronic flight instruments.
Kitplanes Magazine contributor Ed Kolano takes a first look at the Sherpa utility aircraft.
Video Archive
