 Hobby
 Subscriber Log-in
 Get Web Access
 Magazine E-Library
 Classifieds
 Aircraft Directory
 Supplier Directory
 Reader Feedback
 SportPlanes
Links
 Back Issues
 Shopping
 Bookstore
How to Advertise
 Event Calendar
Wind Tunnel
The structural origins of flutter.
By Barnaby Wainfan
Balancing control surfaces requires care and, often, special tools to properly support the surface and yet allow it to move with little friction. Here, the expected weight of the paint to come is temporarily applied to help get the basic balance right. Final balancing must be done after the paint is applied.
Last month we started a look at aeroelasticity. As we saw, airplanes are not perfectly rigid. No matter how stiff the structure is, it does distort under the influence of aerodynamic forces. And structures do not just deflect; they can also vibrate or oscillate.
Flutter is a sustained or increasing oscillation of the airplane’s structure that is driven by aerodynamic forces. Sometimes flutter appears as a sustained limit cycle oscillation that maintains a steady amplitude, but does not damp out. Such a flutter is often referred to as “buzz.” It is undesirable because of the cyclic loads it puts on the airframe, which can cause failures due to fatigue or working fasteners loose. In general, having a sustained aerodynamically driven oscillation in the airframe structure is considered unacceptable for safe operation of the airplane. …
Electronic Subscribers: Click Here for the Full Story
Non-Subscribers: Click Here to Subscribe
Pay Per View ($7.50)
Headlines
KITPLANES sits down with Advanced Flight Systems' founder Rob Hickman to examine his new synthetic-vision EFIS.
JPI's Lance Turk explains the features of the new JPI EDM-740.
Ever wonder what it takes to be the largest kit manufacturer in the world? KITPLANES editor Marc Cook takes a tour of Van's Aircraft in Aurora, Oregon.
KITPLANES editor Marc Cook visits Matco Manufacturing near Salt Lake City to see how the company's brakes, wheels and master cylinders are built.
Get an inside look at how Dynon builds and tests its electronic flight instruments.
Kitplanes Magazine contributor Ed Kolano takes a first look at the Sherpa utility aircraft.
