Shop Tips
February 2014 Issue
Marking a Constant Gap
Save time and effort marking a uniform trim distance.
Many times, a builder needs to mark a constant gap, or distance, from an irregularly-shaped line. An example would be trimming a wing intersection fairing so that there is a constant gap between the fairing and fuselage for a seal. You can do this by measuring every inch, then connecting the dots—or much more quickly using a scrap of material with a hole drilled at the correct gap distance. Drill the hole the size of the tip of a Sharpie fine-tip marker, and the tool is complete!
A short scrap of aluminum, bent to make a handle, is all you need to make this special tool. Dressing the edges makes it slide easier.
The hole should be sized to perfectly fit the marking utensil to be used—in this case, a fine-tipped Sharpie.
The tool in use—saving time and effort to mark a perfectly uniform trim distance.
Download File
Photo by Richard VanderMeulen
Video Archive
PO BOX 8535
Big Sandy, TX 75755
