The complaint was that starter cranking was slow and anemic. Must be the battery, right? Nope. The main negative lead to the battery was found to be corroded and of the wrong internal diameter, not allowing good contact with the battery. The wrong size hole on the battery cable really reduces the contact area on the battery stud, severely limiting amperage, and in some cases will eventually cause enough heat to burn through the connector.
In Case You Missed it
Mel Asberry - 0
Whats changed with the advent of the revised 51% rule? Fortunately, not as much as you might think.
2012 Engine Buyers Guide
In Part 1 of our 2012 Engine Buyer’s Guide, Marc Cook explores what’s currently available in traditional powerplants, and why such engines might be the best choice for your homebuilt aircraft needs.
The $30,000 RV-9A
Two builders helped each other build RV-9As, each employing significantly different outlays of cash. The results are impressive in both cases, but for different reasons. They help us ponder the question as we build: What is something worth? By Marc Cook.
Know (You May Be) the Limit
Kerry Fores - 0
I was in a bad place. I knew the flight might not end well...
