This rudder stop on a Kitfox was barely touching the rudder horns and was close to imminent failure, which could have caused binding of the rudder, most likely at the most inopportune time. Welded tabs used as control stops on tube-and-fabric aircraft such as these are fine, but they usually require some fine-tuning once the aircraft is completely assembled.
In Case You Missed it
Wind Tunnel
Involved in the flight testing of a friends aircraft, Barnaby Wainfan contemplates the consequences (and wisdom) of designing an aircraft around an engine that may prove unsatisfactory or, worse, unavailable.
Down to Earth
Amy Laboda - 0
Everyone can use another set of eyes on a project, and sometimes a technical counselor is just the one to provide them. By Amy Laboda.
Free Flight
EFISes provide a tremendous amount of information and extend the capabilities of todays homebuilt aircraft, but only if you take the time to learn how to use them properly.
