A slight sticking was noticed when the throttle was moved to the full open position. Further investigation revealed that the nut and cotter key were catching on the fuel servo hose and had almost cut completely through the firesleeve. Rerouting the fuel servo hose prevented the interference.
In Case You Missed it
Metal Magic: Drilling Like a Pro
It pays to get good with drilling because you'll be doing a lot of it.
Blind Rivets: Look Closely
Many aircraft kits are designed around the use of blind rivets—also known as pulled...
On Getting Dark
Tom Wilson - 4
Tyrants make memorable flight instructors, a good thing when the lessons being imparted need...
Wind Tunnel
Increasing the weight of an aircraft will affect its performance in all phases of flight.
