Many times starting problems can be traced to spark plugs with high resistance. The high resistance of the plug can make it very difficult for the magneto to fire a spark, especially at lower starting rpm. Long-term wear of the magneto points can become a problem as well. The plugs should be checked at the annual condition inspection, every 100 hours, or whenever starting problems are noted. Tempest makes a really nice go/no-go tester, but you can use a normal ohmmeter as well. Resistance should be less than 2K ohms when tested across the center electrode. Most new plugs will indicate around 800-1200 ohms.
In Case You Missed it
Engine Theory: Engine Cooling-Avoiding Meltdown
Tom Wilson - 0
Understanding the differences between air- and water-cooled engines.
Thin-Wall Close-Quarters Sockets
Don't you hate it when the nut is so close to a rivet...
