Back Issues
September 1986 Issue
Negative-Stagger Biplane (Durand Mark V), Sept., p. 11.
Subject: metal_designs, biplanes, aircraft Aircraft: Durand Mark V
To continue reading this entire article you must be a paid subscriber.
Subscribe to KITPLANES
KITPLANES® magazine is the world's #1 homebuilt aviation magazine. Written for people interested in building, flying, designing and maintaining their own amateur-built category, manned aircraft, each issue is packed with need-to-know information.
Already subscribe but haven't registered for all the benefits of the website? Click here.
Subscriber Log In
Forgot your password? Click Here.
Untitled Document Homebuilder's Portal by KITPLANES
Photo by Richard VanderMeulen
Leedom-Hlavac-KitFox-LiteN200HL started life as a KitFox Lite kit. The engine is a Rotax 503 with a 3.47:1 reduction. The motor mount, carbon full cowl and the gear legs with coil spring absorption are all original designs. Mounted to the 503 is a 70" Warp Drive 3-blade prop and spinner. Standard-grade aircraft tires with hydraulic disc …
Darrell Anderson VanAfter on-and-off construction started in November, 1991, N144DV took to the air on July 4, 2016. (Yes, that's 25 years into a 3-year project!) A little over a year later, with only 50 hours on the Hobbs, I flew it from Montana to Oshkosh AirVenture 2017. I was honored to be awarded a Bronze Lindy …
Dave Armando Kitfox Speedster Model VAfter 6 years of building my 2001 Kitfox Speedster Model V was flown. Equipped with a Jabiru 3300 120 hp 6 cylinder, swinging an IVO medium constant speed prop, my own designed smoke system, Grove gear, Maule tail wheel, removable wing tips with a fishing pole locker inside, Super Bee lithium battery for weight reduction, …
Whether you are upgrading the audio system in an older LSA or experimental or building a new project, PS Engineering and Garmin have non-certified audio panels equipped with advanced features better suited for smaller cabins.
Video Archive
PO BOX 8535
Big Sandy, TX 75755
