Home Search
Rapid Prototyping and Experimental Design - search results
Aliant Ultralight Batteries from Essex Parts Services
...to 7,000 cycles at 70% depth of discharge. Aliant also uses top-of-the-line, UL1642 certified, cylindrical cells that provide you with rapid complete charge time, low self-discharge rate, long life span,...
Bright Idea
...a wide, round, even flood of light to minimize head turning; offers variable brightness and switches on-off with a rapid hand swipe in front of the unit. It’s $89 retail....
Back in the Saddle
...– I’m flying. But every once in awhile, forces conspire to keep me out of the cockpit – for instance a couple of weeks ago, I had a rapid, unscheduled...
Pioneers and New Directions
...into sky taxis. Chris Hawkins’ approach to a Sky Taxi. Dr. Dan Raymer and Sparky Flapjack Dr. Seeley asked Dan Raymer, author of several books on aircraft design (http://www.aircraftdesign.com/), to...
Convergence at CAFE’s Electric Aircraft Symposium
...air transport technology and convergent aeronautic solutions – a phrase heard frequently during the symposium. Testing flows quickly, relying on “pitching” of ideas, fast development and rapid follow-up. Creative approaches...
Wednesday at Reno
...rapid, yet controlled manner when the engine let go. Central to the failure is it takes a trained octopus to fiddle with the manual throttle, mixture, propeller, ADI, ignition and...
One Week Wonder Day 1–The Race (Against the Clock) Begins
...employees and pre-determined leads. Building starts. This build is following a modified order to ensure rapid success. Wings were a priority and they were completed today. Tomorrow, drop-in volunteers will...
EAA-Led Reform Ideas Include LSA Weight and Homebuilt Regulations
...area of sport aviation. “This is a lengthy process, so as much as we might desire rapid change in some areas, the rulemaking process is not built that way,” Elliott...
Garmin begins seamless integration between FltPlan.com and Garmin Pilot
...have made rapid progress in merging portfolios. Beginning next week, pilots will be able to use FltPlan.com for pre-flight planning and filing, and automatically view the same flight plan within...
RANS S-21 Outbound
Randy Schlitter, owner of RANS Designs, Inc., has been working on an all-metal utility airplane kit for going on three years now. Subscribers to his newsletters have tracked the progress...
