Home Search
kitfox - search results
Down to Earth
...Airline Transport Pilot rating, multi-engine and single-engine flight instructor ratings, as well as glider and rotorcraft (gyroplane) ratings. She’s helped with the build up of her Kitfox IV and RV-10....
Zen Four a Day
...main wing. (The gap here is less than you see in a Kitfox, though.) Finally, the CH 750, as the newest member of the clan, represents the family’s latest thinking...
Around the Patch
...8, the Belite is a distant cousin of the Kitfox Lite, developed by James Wiebe in Wichita, Kansas. It can be built as a true FAR Part 103 ultralight, or...
The State of Auto Conversions
...seeing more and more of them at airshows and fly-ins in smaller Light Sport Aircraft types such as the Avid or Kitfox. At the bigger shows, you’ll find these engines...
Down To Earth
...Airline Transport Pilot rating, multi-engine and single-engine flight instructor ratings, as well as glider and rotorcraft (gyroplane) ratings. Shes helped with the build up of her Kitfox IV and RV-10....
Amy's RV-10: Checking Out a Newborn Engine Before Flight
...with the same aplomb as the one in our Kitfox 4 has done for seven years. I like the simplicity of this box. Hit the master and it is on,...
Sennheiser Introduces S-1 Passive Headset
...is running. My Kitfox 4, with its Jabiru 2200 engine, for example, really doesn’t make the same noise as the RV10, with its IO-540 Lycoming roaring at 2700 rpm on...
Brad Cohen's Zenith Zodiac 601XL
...a family. I looked at other planes; The Kitfox (I really wanted something metal), The RV Series ( I have friends, but none close enough to crawl in the back...
Airframes Alaska T3 Tailwheel Suspension
...– Available mid-July 2015 for experimental LSA (homebuilds, Kitfox, Rans, etc) with 1320 lb GW T3 Super Heavy Duty – Double coil design available mid-August 2015 for heavier experimentals (Maule,...
Extreme Fun
...we got an opportunity to fly the new Kitfox STi with a STOL wing and 180 HP Titan engine. Not wanting to wear out the big 29” Alaskan Bush Wheels,...
