Kitfox with a Rotec
America's favorite "cute"airplane finally gets a real (Australian) radial on the nose.
kitfox rotec 594
Performing flight evaluation must look pretty cool from the outside—arrive at the manufacturer’s place of business, hang out a bit, drink coffee, fly to your heart’s content, and go home. Ah, no.
kitfox bumpcowl
A traditional “bump cowl” highlights the Rotec’s very radial-ness.
The reality is quite different. Instead, you arrive slightly late from the previous, hectic assignment because of headwinds, fret about the local weather for flying and the quality of the sunlight for photos later, tour the facility, shoot about 700 photos (knowing you’ll delete 675 of them later), prepare the camera ship for air-to-air later in the day, dump a prodigious amount of data onto a digital-video camera’s slightly unreliable SD card and, somewhere in there, wolf down a Subway lunch. Fun? Of course. Glamorous? Not in the least.
This illustration is presented to help you appreciate the sybaritic glory of this day with the Kitfox group and the Rotec-radial-powered model. We—Paul Bertorelli and I—performed all of the usual duties, and had just completed our air-to-air photo shoot. These missions are almost always scheduled for first or last light to help make the subject appear more dramatic in the cold-eye digital cameras we now use, and it’s common to complete the flight right at the edge of darkness, dog tired, ready for a quick dinner and a hotel-room bed.
kitfox looks bigger
Looks bigger than a regular-edition Kitfox, doesn’t it? Well, it’s not. Aside from the new gear, the airframe is identical to the other Super Sports from the firewall aft.
But on this day, Kitfox’s owner, John McBean, began to pull the Rotec machine into the hangar and stopped, peered out to the west. “Marc, we have 15 minutes of sunlight,” he said, smiling conspiratorially. “We need to go for another flight.”
kitfox tidy installation
It’s a tidy installation of a nicely finished but generally conventional (if quite small) air-cooled radial.
I didn’t need to be asked twice. We clambered aboard the bright yellow Kitfox, the seven-cylinder, 110-horsepower Rotec R2800 still ticking toward cool from the previous flight, and fired her up. I’ve flown in enough radial-powered aircraft to appreciate that there’s a specific starting sequence. Bringing a Pratt & Whitney to life requires knowledge, skill and finesse—and a fair bit of luck. In essence, though, McBean flipped the master on, checked to see that the glorious natural-finish wood Sensenich prop was clear, and let it crank. Three or four blades later, the Rotec was alive, making all the right clattering and clanking sounds you expect from a radial engine, only in a higher scale. Stands to reason, actually: The “2800” in the Rotec’s nomenclature isn’t cubic inches, it’s cubic centimeters. At 2.8 liters, the Rotec has less displacement than the six-cylinder in the Nissan Altima inevitably tailgating you on the highway.
kitfox wing
Kitfox introduced a new smooth wing that no longer uses the scalloped leading edge. This one is composite under the fabric.
kitfox noglass
Kitfox owner John McBean almost said “no glass,” but couldn’t resist the Garmin GPSMAP 696 moving map. The rest, alas, is pretty basic.
As we taxied for takeoff, the view over the nose had become familiar. Where the usual Rotax slope—made possible by the compact Rotax 912S currently the most popular engine for the Kitfox—provides excellent visibility, you’re forced to be more cautious with the Rotec’s wonderfully anachronistic ring cowling blocking the way. There’s just enough gap between the back of the engine and the boot cowl that you can see a sliver of sky between chunks of finned aluminum cylinders, an unexpected pleasure for the mechanically inclined.
kitfox sling seats
Comfortable sling seats offer reasonable room for large occupants. The seats don’t adjust, but the rudder pedals do.
Get in the Box
Fitting a radial engine is always a compromise. In the Kitfox Super Sport, the prop flange is very close to where it is with the 912S. You don’t want to go messing with thrust lines any more than you have to on an established design, but you must also balance forward view and prop clearance. The Rotec Kitfox finds a happy center here.
Visual deception continues, as the Rotec appears to be significantly larger and heavier than the flat-four Rotax, and would seem to be stubbier—a big, round engine without a lot of depth. Not quite, as most radials place the accessories such as carburetor or injection, ignition, fuel pump and vacuum-pump drive directly behind the crankshaft. In fact, the Rotec, at just shy of 26 inches deep—prop flange to carburetor throat—is almost 4 inches deeper than a 912. And at approximately 240 pounds dry (including major accessories), it’s no lightweight; the Rotax installation is some 80 to 100 pounds lighter overall despite needing coolant and a radiator. Both have gear-reduction drives, too; the Rotec’s is a 3:2 ratio using planetary gears. When the engine is at max power (3600 crankshaft rpm), the prop is turning a leisurely 2400 rpm.
kitfox lexan doors
Lexan doors combine with a full overhead glass panel to provide exceptional in-flight visibility.
kitfox flaperons
Flaperons continue to be a Kitfox design hallmark. They move individually for roll and extend together for flap effect.
For reasons of appearance, McBean fitted a lovely all-wood Sensenich fixed-pitch prop that he admits is not precisely the ideal diameter and pitch for the airplane. Despite having 10% more power, the Rotec Kitfox is a tad slower than a 912-motivated Super Sport. You can blame the prop and the additional cooling drag of the radial for the bulk of that. It’s also possible that there’s more thrust to be had by fine-tuning the single Bing carburetor that feeds the R2800.
So, Who Cares?
Again: Who cares? McBean and his crew built the Rotec airplane not for speed or efficiency or cost…or anything as mundane as that. No, they constructed it because it is extraordinarily, undeniably cool. Any protracted discussion about performance and weight distribution should end right there.
kitfox baggage
This large baggage bay can hold 150 pounds.
Compromises in payload, center of gravity or fuel consumption become utterly moot once you’ve pushed the throttle forward on takeoff. Even though the Rotec Super Sport isn’t feathery by Kitfox standards, it’s still a light aircraft. You could build it to the 1320-pound LSA maximum, but the structure can handle a max-gross weight of 1550 pounds with upgraded landing gear. What’s more, there are engineering documents clearing the Kitfox to weights beyond that.
Still, 110 hp in a 1320-pound airplane makes for a spirited weight-to-power ratio, and the Rotec Super Sport doesn’t disprove physics. Acceleration is good—though the 912S feels just as snappy, something I’d put down to weight differences as well as to perception. The Rotec feels like it’s loafing, hardly breaking a sweat as it kicks out a true-to-life radial soundtrack and a vibration signature that’s pure round engine—engrossing, delightful, wicked good fun. The Rotax 912, on the other hand, is a box full of angry insects: a smaller engine, turning faster, working hard to get the job done.
kitfox hand prop
Part of the cold-start ritual is to rotate the prop by hand to ensure the lower cylinders have not filled with oil. Yes, just like the big radials.
Cost and tone are not related. Indeed, the Rotax engine, in its basic form, is more expensive than the larger Rotec radial, but differences in the firewall-forward package and other items you’ll need to complete the installation bring them to near parity.
The heavier Rotec means the tail comes up a bit quicker and then you’re rewarded with your first really good view of the runway centerline. Count to three, and you’re off. The first impressions are of a far more substantial airplane than the 912-powered Kitfox and, again, I think much of that is subjective. A heavier engine will move the empty CG forward, which improves longitudinal stability, all else being equal. While the Kitfox’s mix of light and responsive ailerons and heavier, resolutely stable pitch feedback remains, the balance is tilted away from mini-fighter toward something like a Waco missing a wing.
kitfox supersport
Stately
On our late-afternoon flight, we leveled off at 500 feet (or so), throttled way back and enjoyed the view. McBean is too close to the project to appreciate the subtleties, I think, and that’s easy to understand. Your mind locks onto development of items such as landing gear, cooling configurations, carburetor jetting—to say nothing of wondering how the heck to market the airplane. That might explain his surprise when I looked over and said, “Stately.” “What?” “Stately,” I repeated. That’s what it is. A solid, quiet, tamer Kitfox (at least in the air). I had the mental image of a hawk, circling slowly, barely moving its wings. McBean looked back like I’d just kicked him in the kneecap. “Damn. That’s the word. I’ve been trying to describe it, but that’s the essence, isn’t it?”
kitfox specs 1
Specifications are manufacturer’s estimates and are based on the configuration of the demonstrator aircraft. As they say, your mileage may vary.
With the sun well below the mountain range to the west, we circled back over the horses in the field just beyond the runway fence—they were nonplussed—and made a nice wheel landing in the now-still air. The Rotec version debuted a new style of landing gear that’s as much for reducing weight—on the order of 8 pounds less overall—as for keeping the nostalgic lines going. In place of the Grove-built, U-shaped aluminum gear that’s been extremely popular on the regular Kitfoxes, the company fitted a new steel-tube, Cub-like affair with spring cartridges underslung. It’s a little more work to build than simply bolting up the Grove gear, but it definitely looks the part.
More changes for the basic Kitfox Super Sport arrived with the Rotec. A new leading-edge treatment for the fabric-covered wing eliminates the decorative rib “humps” and replaces them with a composite leading-edge skin that extends back to 12% of wing chord; it’s secured under the fabric. McBean’s hope was to reduce stall speed and improve cruise speed, two points he intends to verify with a 912S installation to eliminate the Rotec variable.
Pushing Back, Looking Forward
We rolled the Rotec Super Sport into the hangar and watched a droplet of engine oil form in the exhaust stack. “Yep,” McBean said, walking away to find a rag and a drip pan. “It’s a radial.”
kitfox gear
Cub-like maingear is new with the Rotec installation, and can be ordered for any taildragger Kitfox.
No sane pilot would question the pure “rightness” of the Kitfox carrying a true radial engine, nor would any industry watcher think that it will be the company’s volume leader. “In a lot of ways, we did this to see if we could,” says McBean. “It was a fun project, and we’ve had great response.” Right there is reason enough to embark on a project like this—it’s the halo effect. Pilots and potential builders will see the retro-yellow Kitfox, find themselves standing in front of it at airshows, nodding and saying, “Neat.”
kitfox wood prop
It just wouldn’t be right to put a plastic propeller on a radial, would it?
The buzz generated by this bee-yellow Kitfox is allowing the company to continue its development efforts. McBean says a number of new items are in the works, though he’s a bit coy about their actual form. He says that revisions to the Kitfox’s wing could help dramatically improve its STOL capabilities, and that he’s been looking into some advanced composites—take that to read carbon fiber—to help reduce empty weight. Approximately one factory-built SLSA rolls out of the Homedale, Idaho, shop every other month, contributing to the bottom line and providing another opportunity for the company to refine the kits. There’s nothing like having to build your own product to instigate small but useful updates.
So is this Rotec-powered Super Sport the best Kitfox ever built? From a dispassionate point of view, no, probably not. But is it the coolest thing you’ve seen in a long time? If you don’t think so, we respectfully suggest you check your pulse.
For more information, call 208/337-5111, or visit www.kitfoxaircraft.com.
kitfox horizontal stabilizer
An airfoil-shaped horizontal stabilizer is optional—as opposed to a simple flat surface. It improves low-speed response.
Previous articleTwo Cub Kits Approved by FAA
Next articleUpdated AvMap Available
2 COMMENTS
