![[Credit: Mike Davenport]](https://www.kitplanes.com/wp-content/uploads/2026/02/DSC_0053-1024x682.jpg)
Located in a private hangar on the west side of the Langley, British Columbia airport is an airplane every bit the same age as the airport. This airplane is still performing the duties that it was designed for 84 years ago. How many of us can say the same thing?
The CP65 Porterfield Collegiate is owned by Wendy Nagasaka and is based in Langley. Werner, her late husband, Werner Griesbeck, had been part of the activity on the airport for many years as an air traffic controller, flight instructor and an aircraft owner and restorer. He had restored 40 plus aircraft including 5 Piper Cubs, the Porterfield and a Fairchild 24 as well as assisting in a number of others, including a Beech Staggerwing and my Stinson.
The Porterfield was designed and built in 1939 in Kansas City, Missouri by the Porterfield Aircraft Company as a contender for the Civilian Pilot Training Program. It was competing with Piper’s J-3 cub, the Aeronca Defender and Taylorcraft’s L-2 for a share of that burgeoning trainer market. While the J-3 was the ultimate winner of that competition, the Porterfield certainly did its share.
Construction of Porterfield’s two seat tandem aircraft consisted of a simple fabric covered wing with two spruce spars and wooden ribs attached to a rag and tube fuselage mounted on conventional gear. The prototype was originally powered by a 50 horsepower Continental engine. The design was later powered by a variety of engines; in addition to the Continental they included both Lycoming and Franklin as lower cost options. The design was firmed up by May of 1940 as the CP65 powered with the Continental A65 and serial #1029 was one of the approximately 400 built before production ended in 1942. But in the fall of 1941 sales were slow and while #1029 was manufactured on November 5, 1941, it was apparently stored until November 8 the following year before being assembled and assigned a registration number.
![[Credit: Mike Davenport]](https://www.kitplanes.com/wp-content/uploads/2026/02/DSC_0022-1024x682.jpg)
Registered as NC37899, the aircraft began its first career as a trainer in the Civilian Pilot Training Program (CPTP). Built as an FP65, it flew 2167 hours with the Franklin 4AC-176B2 engine which was then replaced with a Continental A65-8 sometime in 1947. According to the logs, during the winter of 43-44 it even spent some time on skis. The first three owners kept the airplane in the eastern US in New Jersey until the third owner moved west to Seaside, Oregon. In 1964, it was again sold. This time into the Seattle WA area. From there, it was moved to Chelan, WA. In 1968 it arrived in Canada and was registered as CF-RKU. It was flown extensively with cross country trips around BC and as far north as Whitehorse in the Yukon. After a particularly hard landing, RKU became a project and changed hands two more times before Griesbeck obtained it from a local air cadet squadron in Mission, BC. He restored it over a 4 year period between 1976 and 1980. The fuselage was stripped, sandblasted and coated with an epoxy. As the original wings had deteriorated to the point where they were only good to be used as patterns, new spruce spars and ribs were fabricated. The plane was covered using PolyFibre and painted ”Pontiac Red” for the fuselage and “Nevada Silver” on the wings as per the original factory scheme. He did make some changes, adding a wind driven generator to provide power for a radio and a transponder, necessary to survive in today’s positive control zones. These two are located in the left wing root above the pilot’s shoulder. No provision has been made for a starter so hand propping is still the order of the day. The gas gauge while simple, is very accurate. Not too much can go wrong with a bent wire stuck in a cork and protruding through the cowling above the 13½ gallon main tank. A friend and FAA inspector in Riverside California, Leroy Blum who also owned a Porterfield helped with a 337 form which allowed the addition of a wing tank. This holds another 7 gallons which increases the range by about 50%. He also reinstalled the factory optional skylight with new Plexiglas. No changes are possible to the interior so it is as tight as it ever was. This is without a doubt the skinniest airplane I have ever seen and you can confirm this by standing behind one to see how just little is really there. Since at 5 ft. 5 in. I actually fit in the front seat; it is a mystery to me how anyone much taller and wearing a parachute ever was able to get into either the front or back seats. (Parachutes were required by the CPTP for spin training). According to Joseph Juptner in his 1980 volume #8 of US Civil Aircraft, “it would recover hands-off from a 6 turn spin in 1 turn or less”. Not something I’m likely to try to confirm.
The instrument panel is appropriately basic for a day VFR trainer. The principal instruments left to right are the airspeed, altimeter, magneto switch and tachometer. Above that is the compass and the oil pressure and oil temperature gauges. Under all of that you will find the carb heat control, a skid ball and the cabin heat control. To the left of the panel are the throttle, primer and the fuel shut off. The fuel shut off is a large black lever that is clearly in the way of everything in the off position and folds down and flat against the side of the cabin when on. The throttle and fuel shut off are duplicated in the back for the instructor’s use.
Elevator trim is managed through a small crank located under the seat that changes tension on two springs attached to the stick. The mechanical drum brakes are heel operated and at first blush they may seem awkward but in actual use are completely natural.
Since the restoration was completed, RKU has never been a hangar queen and has been flown regularly in BC, Washington and Oregon. In 1981 he took the Porterfield to Oshkosh while dealing with flight issues related to flight at gross weight with the 65 hp engine. Camping gear and a 240 lb passenger added to the excitement and this likely was the prime motivator for the later engine upgrade.
![[Credit: Mike Davenport]](https://www.kitplanes.com/wp-content/uploads/2026/02/DSC_0042-1024x682.jpg)
Over the years, He had shared her with a number of local pilots including myself. I first flew RKU in the 1980’s when Werner used it to give me, then a brand new pilot, a tailwheel checkout. Years later, I put a few more hours on it giving Young Eagle rides and flypasts at the Abbotsford Airshow and while I saw the airplane parked behind my Stinson every time I went to my hangar, it would be 15 years before I flew her again.
I was a current “taildragger” pilot with 700+ hours in my Stinson 108 in addition to assorted Cub, Champ and RV6 time. However, as the insurance company wanted a minimum of 2 current hours in the Porterfield before adding me to the coverage; that and common sense said it was time to renew my acquaintance with the old girl while under supervision.
As the supervisor is not only the owner, but a former flight instructor, a retired air traffic controller and by the way, remember that as this is the same guy who restored her, there could be no pressure – right! That same Teutonic predilection for neatness and correctness in all things that got him this far extends well into his training skills. There is no expectation other than perfection. At the end of the day, I crawled back into my Stinson just to see if I actually did know how to fly. Wheel landings that I accept as normal on pavement are not permitted. They must be 3 point regardless of the number of bounces. The Porterfield’s narrow gear is quite stiff contributing to some degree of “crow hopping” and surprisingly, once down she will roll and roll, probably right off the end of the runway if left to her own devices. The drum brakes, while used mainly for run-ups will slow you enough to make the turnoff.
Flight in the Porterfield is a delight. To give the old bird a bit more oomph, Werner had used another 337 form to upgrade the engine to a C85-8 from the original C65.This makes a remarkable difference in climb rate. With two lightweight pilots on board, the 85 hp Continental had us airborne in seconds. Take off power could be applied immediately and did not require the application of right rudder that I am used to in my Stinson. The ball stayed in the centre, more or less, with occasional reminders from the back seat. Visibility from the front seat is exceptional in all directions. Downwind is flown at 80 – 85 mph and final at 70 slowing to 60 over the threshold. Power off on final but be spring loaded to add some if needed. I round out a little too high each time so that my landings are more arrival than touch down. Once down, I add power and do it all over again and again until the GIB (guy in back) is satisfied.
I once again went solo in RKU. The Porterfield is even livelier than I remembered it. It got off in half the space and time and the climb rate at or near 1000 fpm was significantly better than I remembered. The extra 20 hp of the C85 certainly made its presence felt. Without the GIB the ride was also much quieter but the ball wandered just as much. Landings went from good to less good but the airplane is still useable.
Porterfield CF-RKU is the only one registered in Canada and a recent search of the FAA’s registry web site lists just 68 active aircraft in the US. A delightful and rare aircraft. Due to health issues, it is once again available for purchase, hopefully by someone who will provide the same level of care that Werner had provided for the last 47 years.
![Vintage in Review Returns to AirVenture 2026 With 90-Year-Old Flyers The Granville Brothers Gee Bee R-6 “Q.E.D.” being serviced before the 1934 MacRobertson Air Race; Mid America Flight Museum flies a replica of this aircraft. [Credit: Wikimedia Commons]](https://www.kitplanes.com/wp-content/uploads/2026/07/Screenshot-2026-07-17-at-3.09.57-PM.jpg?w=218&h=150&crop=1)
![Vintage in Review Returns to Oshkosh: Five Days, Five Stories, and a Living OX-5 [Credit: EAA]](https://www.kitplanes.com/wp-content/uploads/2026/06/vintage-in-review-herb-clark.jpg?w=218&h=150&crop=1)
![Golden Age Revival The newly-restored F-24 enjoying the morning sun. [All Images Credited to Mike Davenport]](https://www.kitplanes.com/wp-content/uploads/2026/05/DSC_0001.jpg?w=218&h=150&crop=1)
![Winging It [Credit: AdobeStock]](https://www.kitplanes.com/wp-content/uploads/2026/05/AdobeStock_262642207_AGCuesta.jpg?w=324&h=160&crop=1)
Really poor form for hand-propping in the picture.
And what does this factory built airplane have to do with kit planes, anyway?
Homebuilders are interested in all types of aircraft, including vintage aircraft. Many homebuilders also restore and enjoy flying vintage type-certificated aircraft.
Great. BTW I own Porterfield Collegiate N27291 in central California. I bought it from the Le Roy Blum, who was mentioned in your article.
Part owner in Porterfield CP65 N32431 based at Lompoc, CA from 1963-66. Took my CFI check ride in the back seat of the Porterfiefd.
