Home Search
Rapid Prototyping and Experimental Design - search results
Error Chain
...I’ve done everything you’d see and do in a normal condition inspection. But these are Experimental aircraft. Proven design or not (and the Cassutt is a very well proven design...
Best Practices – Sealants
This is the beginning of a new series on best practices in Experimental aircraft construction. In other words, it is a series about the right way to build an aircraft...
Smart Transponders
...a Mode S unit designed and built by Trig Avionics. This is a rack-mounted design with 1090ES ADS-B Out capability and is also plug-and-play with vintage KT76A/C models. But, like...
Free Flight: Embracing New Ideas
...engine failure had been considered, and the airplane had been designed to operate all the way across the ocean on a single engine. The designers coordinated this with the licensing...
What Do I Call It?
...the word “Experimental” alone as a type ID. For much of the past two years, I have called myself “Experimental Jet 958PD”, with the hopes that it at least gives...
Geared Drives Remembered
...that original story, we’ll take a few pages to pay respects to a man whose hard work benefitted the Experimental community in myriad ways. It was the kind of news...
FAA Previews Task-Based Testing for Experimentals
...could “revolutionize” flight testing for Experimental/Amateur-Built aircraft, recently called attention to recent draft changes to Advisory Circular 90-89B, which forms the guidance on Phase I flight testing. In it, the...
