Home Search
kitfox - search results
Super Legend HP
...as CubCrafters, Aerotrek, RANs and Kitfox—the taildragging rag-and-tube crowd. (Oh, and did we mention Kitfox and RANs also have their own versions of Titan-powered airframes?) The Legend HP, like the...
Checkpoints
...we’ve always either had the airplane at home in the garage (Kitfox) or in the hangar at our home. While the temps aren’t nearly as cold (the 18 degrees here...
Unairworthy
This was discovered on the initial airworthiness inspection on a Kitfox. No pitch control stops were installed, allowing the full-forward movement of the stick to cause jamming of the pitch-control...
...editorial [“While I’m in Here,” October 2017] because I’m exactly in the middle of what you wrote about. My EGT probe went out on my Kitfox with a Rotax engine....
Unairworthy
This rudder stop on a Kitfox was barely touching the rudder horns and was close to imminent failure, which could have caused binding of the rudder, most likely at the...
Unairworthy
On aircraft with folding wings, such as those from Kitfox and RANS, one needs to be careful to mount all wires and tubes on the forward side of the aft...
Whole Airplane Parachutes
...Cirrus SR20 and SR22.” In the kit aircraft world, BRS Aerospace has developed installations for more than 350 models from a wide range of manufacturers, including CubCrafters, Glasair, Kitfox, Lancair,...
...for that aircraft. Question: The FAA is coming soon to sign off (I hope!) my completed Kitfox S7 Super Sport. The inspector told me he wants to see Form 8000-3,...
Propeller Buyer’s Guide
...resellers include Custom Flight Creations, The Airplane Factory, Kitfox LLC, RANS Aircraft, Kaolin Aviation Services and Arion Aircraft. Airmaster electrically controlled constant-speed prop. Arrowprop Company, Inc. Primarily a builder of...
Buying a Used Homebuilt: Different Types
...to be flown by Sport Pilots (Kitfox, RANS, Zenith, Sonex, and others are good examples). The RANS S-21 is the latest in a line of very successful kit airplanes, many...
