Home Search
The Ultimate Upgrade - search results
Tribute to Teachers and Mentors
...was also the same one that I was assigned to. My classmate subsequently became my class instructor for captain upgrade school a year later. His impact and influence were immediate...
Take the Stress Out of Stud Pulling
...mailbox. One exception is if you’re doing an upgrade from magnetos to a P-Mag electronic ignition system, as I’m in the middle of now. Unless you choose to leave the...
Radiant Technology Introduces New CO Detector
...the original Geiger CO in the last 90 days is qualified to receive a no charge upgrade. The Geiger Plus is available on Radiant’s website, as well as Aircraft Spruce,...
Lightspeed Delta Zulu Headset
...you’ll have to come up with something else. But that’s hardly a reason to resist an upgrade to the Delta Zulu—the CO detector and the HearingEQity features alone are worth...
New Landing Light Series from AeroLEDs
...36-4509 and SunSpot 36-4591 are a safety upgrade that is FAA-PMA/STC approved for use in virtually any aircraft that requires a PAR36 lighting configuration.” The SunSpot 36-4000 series also includes...
New A30 Noise Canceling Headset from Bose
Bose’s A20 has proved to be one of the most popular noise canceling headsets on the market but the company figured it’s due for an upgrade. And that will be...
Shopping for Batteries
...The 7025-20 is often advertised as a sealed lead acid upgrade to the popular 225 CCA wet-filled Gill G-25 lead acid model, priced around $250. You’ll pay around $300 for...
La Zoom!
...landing gear upgrade in 2021. This required removing the wing, allowing enlarging the tank-to-fuselage fuel lines from 3/8- to 1/2-inch diameter plus replacing the stock Glasair 90° bulkhead fittings (where...
Lightening the Arion Lightning and Builder Assist for All
Nick Otterback of Arion Aircraft has been keeping secrets. Good secrets. It’s not often a kit manufacturer keeps a significant upgrade to one of their products quiet, but Arion Aircraft...
Hartzell Propeller Updates
...series engines, the props offer performance equal to the metal series with a 20lb weight savings, and will be available soon in either 72 or 74-inch diameters. An upgrade option...
